Using Anaconda py2.7 packages in EventGhost?
jwilcox25
Post by jwilcox25 » Wed Sep 20, 2017 12:42 pm
I've added to PYPATH: C:\ProgramData\Anaconda2\Lib\site-packages
and have the following in PATH: C:\ProgramData\Anaconda2; C:\ProgramData\Anaconda2\Scripts; C:\ProgramData\Anaconda2\Library\bin
Adding the bin directory to PATH helped with DLL not found errors importing numpy. I'm still having trouble importing some libraries eg pandas:
ImportError: C extension: NaT not built. If you want to import pandas from the source directory, you may need to run 'python setup.py build_ext --inplace --force' to build the C extensions first.
Given this is getting to be the most popular Python distro, it would be great to know how to handle this.
