Xiaomi Home : Which API is best suited for Eg Integration?
Foune
Post by Foune » Tue Aug 29, 2017 11:24 am
I'd like the Xiaomi Gateway to generate nice Eg events with payloads. Currently Eg relies on Domotic'z xiaomi plugin, but being dependant of Domoticz is a problem as I depend on third party developper updates, which are frequently needed when xiaomi updates it's protocol (usually for new hardware).
I found two API :
The simpler : https://github.com/jon1012/mihome
The evolution of the previous one : https://github.com/monster1025/aqara-mqtt
I don't know which one is the more appropriate for an Eg adaptation, can somebody look quickly and tell me which one would best match with Eg?
yokel22
Re: Xiaomi Home : Which API is best suited for Eg Integratio
Post by yokel22 » Tue Aug 29, 2017 3:34 pm
They both use MQTT, so either should work. I'd try the second one. It looks like it's setup a bit smarter.
Foune
Post by Foune » Tue Aug 29, 2017 4:52 pm
Thank you for your advice. In fact I don't want the MQTT part, I'm looking for Eg Events, so I'll have to dig on this;
yokel22
Post by yokel22 » Tue Aug 29, 2017 5:00 pm
Sorry, I completely misunderstood what you were asking. Upon actually looking at the source code. They both are using websocket connections for comm with the bridge. There isn't a ton of difference in how the connection is setup. Either one should be adaptable for an e.g. plugin.
Foune
Post by Foune » Wed Aug 30, 2017 8:52 am
Nice.
Last question : do you know a very simple Eg plugin that could be a template for the xiaomi plugin? The main feature is the keep alive mechanism.
yokel22
Post by yokel22 » Wed Aug 30, 2017 5:04 pm
The simplest I can think of off hand is the denon plugin. http://eventghost.net/forum/viewtopic.php?f=9&t=7464. However, that plugin doesn't keep an open pipe for events. It would help with setting up the basic socket connection though. I'll see if I can't find a better example for you.
Also see the socket module documentation here: https://docs.python.org/2/library/socket.html
