Blackout Display
piert
Re: Blackout Display
Post by piert » Thu Oct 24, 2019 10:57 am
Sorry for the late reply, Winver command gives me this:
Post by kgschlosser » Thu Oct 24, 2019 2:35 pm
ok so you are in fact running the latest version.
I am going to key up a simple test script you can run from the command line using EG. it will bypass all of the internal mechanics of EG and isolate only the dll i need it to. need to know if it is a dll issue or if it is an issue with the plugin.
piert
Post by piert » Thu Oct 31, 2019 5:31 pm
Looking forward to it!
piert
Post by piert » Wed Nov 13, 2019 2:19 pm
Anything I can test?
piert
Post by piert » Fri Nov 22, 2019 10:11 am
Kevin, I would love to test if it is a dll issue or if it is an issue with the plugin, have you been able to make a test script for this?
Post by kgschlosser » Fri Nov 22, 2019 7:44 pm
I am going to work on it some today. I had to reinstall the OS on my computer and I have not gotten all of the bits and peices needed to build the dll file installed onto my machine yet.
piert
Post by piert » Sun Nov 24, 2019 9:06 am
Thanks, no rush, just wanted to know if it was somewhere on the radar ;-)
