Plugin: TerraTec Home Cinema
BUddy
Post by BUddy » Fri Aug 29, 2008 8:58 pm
I've coded a little plugin for TerraTec Home Cinema. It is the first release and may not contain all controls, but may contain bugs in coding and spelling :lol: . So try it out and report any bugs you will find and suggestions.
Greeting BUddy
TerraTecHomeCinema.zip
Extract to your plugin folder and restart EventGhost! You can find the plugin under "Program control"
(6.37 KiB) Downloaded 245 times
BUddy
Re: Plugin: TerraTec Home Cinema
Post by BUddy » Sat Sep 27, 2008 4:57 pm
here is a small update for my plugin.
(6.68 KiB) Downloaded 280 times
