I have a config dialog and there are two checkboxes, one for "A" and one for "B"
I would like to create a dependency between them, so that you are allowed to check "A" or "B" but when you check "B", "A" shall be cleared and disabled/gray shaded
Is this possible? Hints are welcome
Kind regards, Walter
Q regarding checkboxes in a config dialog
Re: Q regarding checkboxes in a config dialog
Hi krambriw !
Try import attached plugin "Test" (__init__.py place to folder \plugins\Test).
- __init__.py
- plugin "Test"
- (3.92 KiB) Downloaded 298 times
My dear Pako, this was great!!! Very many thanks,
