May I someways recognize, that an action was starting by the button "Test" in Configuration dialogue ?
Button Test
- Bitmonster
Re: Button Test
Currently only FindWindow is using a non-default Test button behaviour. So you should have good reasons to use something different. FindWindow does it through re-binding the Test button with a custom event handler and not calling event.Skip() in the event handler:
panel.dialog.buttonRow.testButton.Bind(wx.EVT_BUTTON, OnTestButton)
Re: Button Test
Good idea - "Elementary, my dear Watson"
Thanks !
Thanks !
