Using Pythonscript with eg.result and Read Serial Port...
sjolof
Post by sjolof » Wed Jul 09, 2008 8:23 pm
Please help me to solve my problem.
I´m sending "!" to serial port, no problem with that, but I need to check if I get the same character "!" in return before I can send my string.
I want to send "!" maximum 5 times (100msec in between).
If I get "!" in return in less then 5 tries then I could use "Jump" - (If last action successful) and send rest of my string.
But how can I check that I get "!" in return? (read serial port - python script ?) and how to limit to maximum 5 tries?
I would be really happy in someone could help me out!!!
Re: Using Pythonscript with eg.result and Read Serial Port...
Post by Bitmonster » Thu Jul 10, 2008 4:28 pm
Untested:
Serial = eg.plugins.Serial
for i in range(5):
    Serial.Write("!")
    # read one byte with 0.1 sec timeout
    answer = Serial.Read(1, 0.1)
    if answer == "!":
        eg.result = True
        eg.Exit()
eg.result = False
sjolof
Post by sjolof » Thu Jul 10, 2008 11:31 pm
Bitmonster: Thanks for quick reply...
Sadly it didnt work.
Got theese messages:
Python Script
Python script "24", line 4, in <module>
Serial.Write("!")
File "C:\Program Files\EventGhost\plugins\Serial\__init__.py", line 269, in __call__
AttributeError: 'NoneType' object has no attribute 'write'
Any idea someone ???
Thanks in advance!!!
*** Update: Seems to be working on another installation... Must check this further... I will come back with results ***
Post by Bitmonster » Fri Jul 11, 2008 1:23 pm
