It's called the on screen remote and it does what it says.
Multiple remotes are supported.
It is configured with an easy to edit text file.
It can be used with anything with a command line interface.
Click for thread and download
http://forums.sagetv.com/forums/showthread.php?t=29930
I use this to control my DVD changer, EventGhost has been handling those duties via USBUIRT for quite some time. This is just another interface to get your commands through.
I use the network functions in EventGhost (-n 127.0.0.1:1024 PASS EVENT.NAME) to avoid issues with commands coming from both server and extenders.
So far so good but I have no skills with SageTV Studio either so improving and modifing whats on the screen will take time.
