SunTracker plugin
SunTracker plugin
Dear All,
This version of SunTracker is no longer supported. I have made a newer version with additional functionality that you will find here:
http://www.eventghost.org/forum/viewtop ... f=10&t=982
Please use that topic for discussions instead
Based on the same basic ideas as my old script, this is a useful little plugin if you need a scheduler that follows the sunrise/sunset.
First of all, all credits to Bartman, I have based this one too on code and structure from his Timer plugin.
I took it as a little challenge to re-work my script "SunRiseSet" into a plugin.
With this you could for instance fully automate your outdoor lights on your house, in your garden or park if you are lucky to have one. For sure its most useful for controlling lights and with the offset you can also control your indoor lights like I do myself. Maybe I should call the mayor, we could tune the whole downtown...and save some energy too...
I use radio controlled (RF) outlet switches, but basically you can control anything that is supported by EG, just copy and paste the event name in a macro with actions.
Some words about the settings as seen in the picture:
The first 3 fields for tracker and event names are rather obvious.
The longitude and latitude fields are needed to calculate the sunset/sunrise at your location.
For each daytype you have 3 time settings. Write them in format "hhmm" like "1830".
- "Night OFF" means any time between 0001-0559 when you want something to be turned OFF
- "Morning ON" is the time in the morning from 0600-1759 (long morning, yes) when you want
something to be turned ON
- "Evening OFF" is the OFF time in the evening starting from 1800-2359
A typical use-case could look like this
During weekdays, Monday through Thursday, it would be that
- the outdoor lamp is turned ON every morning at "0600"
- it is then turned OFF at sunrise
- it is turned ON again at sunset
- finally, its turned OFF later in the evening, like "2300"
On Friday evenings it would not be turned OFF, instead this happens Saturday night at "0200" (because the kids always arrives home much later during weekends)
For Saturday we do not turn ON the light at all in the morning, everybody is sleeping anyway...Later in the evening, it is turned ON at sunset. The same procedure as for Friday, its turned OFF at "0200" Sunday night.
On Sundays, finally, the same morning and eveing procedure as during Saturdays wih the exception that the lights are turned OFF in the evening at "2300".
During Vacation when the house is empty and you are dancing in Ibiza, another pattern could be applicable...
I hope you got the basic idea behind. The picture below is configured accordingly
There is a checkbox where you can enable/disable the vacation override function. If checked,
all days will follow the vacation schedule.
Then there are public holidays. You have fixed ones and you have variable ones (that changes
every year). So this you need to maintain yearly.
The logic in handling holidays is as follows
- if today is a normal weekday and tomorrow is a holiday, use time settings for Friday
- if today and tomorrow are holidays, use time settings for Saturday
- if today is a holiday and tomorrow normal weekday, use time settings for Sunday
Some devices, especially radio controlled, needs sometimes the command to be repeated. The setting for this is called bursts, here you define how many "copies" of the event you like to create when turning ON or OFF.
Some transmission devices also need a short delay between the transmissions. So there is also a setting for that.
Also it makes no sense to turn on lights if they anyway are going to be turned OFF shortly. Here you have a setting where you define the minimum ON period left to be required.
You can decide if you want the devices to be synchronized or not. This means that if by accident, someone turns a light OFF when its supposed to be ON, it will be turned ON again
at the next synchronization. The interval is also configurable.
If you like, you can specify an offset in minutes for ON/OFF events. A negative offset, as example -45, results in that the ON event is created the specified number of minutes (in this example 45 minutes) BEFORE the actual sunset happens.
The OFF event will occur the same amount of minutes AFTER the actual sunrise. This function is much appreciated when you like to control indoor lights since it's normally getting a bit darker earlier inside than outside.
A positive offset works the reverse way. It creates the ON event specified number of minutes AFTER the actual sunset. The OFF event will occur the same amount of minutes BEFORE the actual sunrise. This function can be used in cases where you think that there is still enough light from the sun also a period of time after the actual sunset and before the sunrise. It depends on your actual location.
Finally, you can decide if you like to have an entry printed in the log window for each loop execution.
Talking about log, in a separate directory, "Log", you find a logfile in html-format holding the on off actions
To make things happen, just do as normal, finalize your settings, create an event with the same name in any macro together with actions.
- SunTracker_22.04.2008.zip
- (61.05 KiB) Downloaded 389 times
Re: SunTracker plugin
A little bug in first version
Here is the update
Here is the update
- SunTracker_28.04.2008.zip
- (61.4 KiB) Downloaded 405 times
Hey krambriwm thanks for this plugin. It's much appreciated since the script was kinda unstable for me.
However I'm having trouble understanding how to use it. I've added the SunTracker Plugin and a SunTracker Action in Autostart. When starting EventGhost I get the message "Today is Saturday. Sunrise will be at 0458 and Sunset at 2118". Finally I disabled the "Log only assigned and activated events" checkbox. Now I'd expect an event to show up in the log at 21:18 which I then could drag&drop on to my macro but it doesn't. I set the synchronization to 6 minutes so one event should show up every 6 minutes, right?
I also tried naming my macros same as Event Name in SunTracker Action and added an Event with the same name but still nothing.
Attached are my settings.
Hello Vuego,
The plug-in assumes that it shall have the role to turn ON and turn OFF selected devices.
You have to define at least a "Morning ON" time, otherwise there will not be any event created. Since B2 is never turned ON, the plug-in never tries to turn it off.
If you put in a "Morning ON" time like 1130 (if you only need evening control because at 1130 the sun is already up and there will not be any turn ON event created), you should expect to see an event every 6 minute or so in the log with your current settings.
Following your example, B2 will be turned ON at sunset and turned OFF at sunrise the following day.
Playing with the time settings you can create many different patterns.
Thanks! That works much better
I was planning to play with the On/Off timers once I got the sun up/down working. That's what I get for being too methodical
Here's one vote for including this plugin in the EventGhost download
Sorry to ask but, how do I know "The first 3 fields for tracker and event names are rather obvious."
I don't get it
How do I know what to put in the "event name on and event name off"
It works if I run the macro but not in the suntracker
Please help
Best Regards
FB
I don't get it
Please help
Best Regards
FB
Hello FB, no problem, cool if you find a usage for it;)
I should maybe have been more accurat in my description what to put in the various fields;
As "event name ON" you should put in a name that is related to what its going to initiate and that is "unique" because this will show up in the log on the left side in EG. Like "My aquarium lamp ON". Then you have to link this event with an action (on the right side of EG) to make things happen. Linking can be done by drag and drop once the event shows up or you can type exactly the same name manually when you first create the event in the configuration tree on the left side.
The same for "event name OFF"
Once you done it correct, the "event ON" will be fired and shown in the log at sunsets. In the same way the "event OFF" will be fired at sunrises.
With this configured correct it should work. If the macros are working fine, its just the matter of triggering them
In my test sample below, my event names are simply "Turn ON" and "Turn OFF" which is normally not enough unique,., I would recommend you to give them a more descriptive name
- Image2.jpg (14.16 KiB) Viewed 10455 times
HI!
Tnx for the information
but I didn't get it to work :S
I tied to add an event but when I did (look at the screen shoot)
What did I do wrong?
eg
ver 03.6.1449
svn 458
windows 2003 server
Best Regards
Fredrik Svensson
eg
ver 03.6.1449
svn 458
windows 2003 server
Best Regards
Fredrik Svensson
Hi again,
It seems something goes wrong with EG itself....
I have not tried running it in Terminal server, don't know if this could be the reason
Besides, if you look at my picture and compare, you can see that you don't have configured any events the same way as I have.
But the problem starts already earlier when EG starts
Have you tried it in another PC running it directly in the OS?
Also, my picture was ment to show you how the macros needs to have an event and an action
You also have to add an action for the SunTracker plugin. You should see a setup like the earlier screenshots above
PS Just tested with 1449 as well, works fine for me, no change
Hi!
Tnx again
Ok I will try working on it
BR
FatBoy
Tnx again
BR
FatBoy
Hello!
I have some problems getting started. I don't understand how to combine the plugins to get it working. I use Tellstick as my transmitter.
I would like to combine Suntracker with manual on/off times for some devices. In total I have 12 receivers.
The first step I understand...
1. I add the modules "Suntracker" and "TellStick" to Autostart.
...after this I am stuck
What should I do next? Add a separate Suntracker for each device I have? How do I combine Suntracker with the TellStick plugin? Do I need one event for ON and one for OFF? Should I put the Tellstick or Suntracker on the toplevel in the tree?
Please, help me getting started...
Hi ja71,
Yes, you are thinking in the right way....
Add the plug-ins themselves as you have done (one for Tellstick and one SunTracker)
Then you right-click on the SunTracker plug-in and create an action (one for each receiver if you need different settings for each)
You will then get a setting dialog where you enter your data like the name of the action, your geographical position (to make it possible to calculate the sunrise/sunset where you live), the name of the events that is going to be generated when the action triggers for ON and OFF...and a lot of other settings. Look earlier in this thread and you will see a typical setting dialog.
Next step will be to create macros, actions and events for the Tellstick. Events must have the same names as you used above in SunTracker dialog
One macro can be used to trigger several receivers even if they have different adressing so you just create the Tellstick macros, add the actions you need and give the events the same names for all. If you need different settings for some, you have to create another SunTracker action. In the picture below you can see an example. I have added a delay between the Tellstick transmissions
Hope this helps a bit on your way, you are welcome with new questions
Hi Walter!
Thanks a lot for a good description!!! Now the picture is getting much clearer.
I don't think I had figured this one out myself...
Best regards
/Jorgen
Best regards
/Jorgen
Hi all,
I've successfully been using suntracker for some time now, however I've run in to problems. I'm getting the following errors:
00:00:01 Today is Monday. Sunrise will be at 0614 and Sunset at 1933
06:00:01 Exception in thread SunTrackerThread:
06:00:01 Traceback (most recent call last):
06:00:01 File "threading.pyc", line 486, in __bootstrap_inner
06:00:01 File "C:\Program Files\EventGhost\plugins\SunTracker\__init__.py", line 1033, in run
06:00:01 File "C:\Program Files\EventGhost\plugins\SunTracker\__init__.py", line 709, in CheckMorningLightOn
06:00:01 File "C:\Program Files\EventGhost\plugins\SunTracker\__init__.py", line 446, in MorningLightON
06:00:01 NameError: global name 'iMinOnPeriod' is not defined
06:00:01
I've two suntrackers, both to set my lamps to go on 0600, 10 minutes lights at least. One tracker is +-0 offset (outdoor), and one is -45 minutes (indoor). Neighter of them works in the morning, and today (and since a few days ) the outdoor lamps didn't go on.
Any ideas?
06:00:01
Any ideas?
HI,
I finally got almost everything working, only one thing left ... if I want to turn off the lights after 2359 it dont work
I have used "Night off" but it wont turn off my lights :S
any suggestions?
BR
Fatboy
any suggestions?
BR
Fatboy
