Help with variables "across" classes
Post by krambriw » Wed Mar 05, 2008 12:09 pm
Can you advice me what is best?
I have in the following example two classes, one eg.PluginClass and one object class. I want to set a variable value (myCounter) in the object class and be able to use it in the PluginClass. How would you write it in python "as professional" as possible? Without using global variables. Hope you understand...
Thanks in advance, Walter
class Device(eg.PluginClass):
    def ReadCounter(self):
        value = myCounter
class Counter(object):
    def Configure(self):
        myCounter = 5
dexter98
Re: Help with variables "across" classes
Post by dexter98 » Thu Mar 06, 2008 5:28 pm
Where are the counter objects created?
If this is done within the plugin class, the variable can easily be accessed from the plugin class.
The best way to access such functionality is through wrapper member functions in the counter class, such as GetCounter. It's best practice not to access the variables from a certain class should directly from other classes (except derived classes).
In your case:
    def __init__(self):
        self.counter = Counter()
        self.counter.Increase()
        value = self.counter.GetCount()
   def __init__(self):
      self.myCounter = 0
   def GetCount(self):
      return self.myCounter
   def Increase(self):
      self.myCounter += 1
      self.myCounter = 5
Post by krambriw » Fri Mar 07, 2008 6:32 am
Dear Dexter, thanks a lot for your advice. I'm experimenting with this now...
