I installed the latest version and a few plugins - I recommend including the plugins in the install on future versions for ease of use and to ensure compatibility
I've seen several issues...
a) I installed the plugins 'MceRemote_Vista', 'XBMC repeat', 'USB-UIRT' but it is not working for me. At first I was not receiveing any errors but commands were not making it to XBMC (dharma rc2) - using Harmony (programmed as MCE remote).
b) Now, 2nd day of using it, I get an error on load of SH... 9:42:19 AM Failed to load actions for XBMC . Plugin not loaded.
- I tried deleting the plugin and reinstalling, same issue
c) SH does not check to see if it is already loaded, so multiples can load into memory - possibly causing hangs (see below)
d) at least 30% of the time SH hangs. It shows loaded in Task Manager with ~11MB used and 0% CPU. I must kill the process. It will allow me to load more and i have had 4,6 processes loaded at the same time - had to kill them all and start again.
- once loaded properly, i have not seen a problem but I have not been able to use it for more then 15 mins or so.
