trying to create plugin for UltraSconi, getting driver error
EG 0.4.0.1397
I'm trying to create a plugin for JBmedia UltraSconi based on WinUSB. The driver is successful created and installed. After the restart of EG i get an error, that the driver could not be opened.
Any hints/tips/ideas what to try out, or check out?
Re: trying to create plugin for UltraSconi, getting driver error
just wondering.
Did you get any specification from JB? I wanted to make a plug in years ago and even received a sample but later JB was not willing to give any support.
- Bitmonster
Does this device actually register as an HID device?
The MS MCE remote for example can also be assigned to the WinUSB.sys driver, but it will not work, because this remote is not a generic HID device.
Yes, it shows up as a HID. With the generic HID plugin i get events like this:
And the events are not always the same for one button.
HID.001C181B1936181C18
HID.001C181C181C323618
HID.001C181C181C181CFE
HID.00FF00000000000000
- Bitmonster
Copy Help>About>System Information here and the source of your plugin.
No, i haven't contacted JB for now. I wanted first see if it works the WinUSB way.Bartman wrote:just wondering.
It's sad that he doesn't want to support you
Bitmonster wrote:Copy Help>About>System Information here and the source of your plugin.
Software
Program Version: 0.4.0.r1397
Build Time: Sa, 23 Jan 2010 09:17:09
Python Version: Stackless Python 2.6.4 final 0
wxPython Version: 2.8.10.1
System
Operating System: Microsoft Windows 7 Ultimate, 64-bit (build 7600)
CPU: Intel(R) Core(TM)2 Extreme CPU Q6850 @ 3.00GHz
RAM: 4094 MB
USB-Devices
USB-Verbundgerät: USB\VID_046D&PID_C505
Logitech Cordless USB Keyboard: USB\VID_046D&PID_C505&MI_00
Logitech HID Keyboard: USB\VID_046D&PID_C505&MI_01
USB-Verbundgerät: USB\VID_046D&PID_C51A
USB-Eingabegerät: USB\VID_046D&PID_C51A&MI_00
USB-Eingabegerät: USB\VID_046D&PID_C51A&MI_01
USB-Eingabegerät: USB\VID_04B4&PID_0316
USB-Verbundgerät: USB\VID_04D9&PID_1603
USB-Eingabegerät: USB\VID_04D9&PID_1603&MI_00
USB-Eingabegerät: USB\VID_04D9&PID_1603&MI_01
USB-Massenspeichergerät: USB\VID_1307&PID_0330
# -*- coding: utf-8 -*-
ur"""<rst>
Plugin for the Ultra Sconi.
.. image:: picture.gif
:align: center
import eg
eg.RegisterPlugin(
name = "JBMedia Ultra Sconi",
author = "topix",
version = "1.0.0",
kind = "remote",
guid = "{EE0AE6B9-E6E5-48C7-8704-90DADB6BE2A0}",
description = __doc__,
hardwareId = "USB\\VID_04B4&PID_0316&REV_0300", # also tried "USB\\VID_04B4&PID_0316"
class UltraSconi(eg.PluginBase):
def __start__(self):
self.usb = eg.WinUsb(self)
self.usb.AddDevice(
"JBmedia UltraSconi",
"{745a17a0-74d3-11d0-b6fe-00a0c90f57da}",
self.ButtonsCallback,
4,
self.usb.Open()
def __stop__(self):
self.usb.Close()
def ButtonsCallback(self, data):
print "UltraSconi:", data
- Bitmonster
Where does the GUID for the AddDevice call come from? Doesn't look like you have created a new one.
The GUID is from Windows Device Manager. I thought the GUID i created is just for eg.RegisterPlugin. Should i use the same GUID for AddDevice and RegisterPlugin?
- Bitmonster
No, you must create a unique one for every AddDevice call.
Ok, no more error, but i get no data from it
Well, i think i should write JB and ask him for help...
Dann viel Glück.
Ich teste aber gerne mit.
@Bitmonster
hat es eigentlich einen Vorteil den WinUSB Treiber statt HID zu nehmen, wenn das Gerät sich nicht als Tastatur und/oder Maus ausgibt?
@Bitmonster
- Bitmonster
This is an english forum, so please continue in english.
In this case most likely not. It might have a better perfomance to use WinUSB, but WinUSB has the drawback of needing a driver installation. So for this device I would stay with eg.WinApi.HID.Bartman wrote:@Bitmonster
