Question: How do I create "getter actions"???
Post by krambriw » Sun Dec 13, 2009 7:47 am
No plugin should ever assign something to eg.globals or change anything in it. Never!
The eg.globals namespace is exclusive for the user's Python scripts and commands.
If your plugin wants to publish variables to the user, the preferred way is to implement getter actions, that simply return the value. This way the user can also easily see all informations your plugin can provide.
I read the above. Anybody that can give a hint/sample code how this "getter action" is made?
Kind regards, Walter
Prinz
Re: Question: How do I create "getter actions"???
Post by Prinz » Sun Dec 13, 2009 9:18 am
krambriw wrote:I read the above. Anybody that can give a hint/sample code how this "getter action" is made?
It's a simple action, which is doing nothing. Only the return value of this action is the contents of a variable or array of the plugin.
After executing this action, the user can work with this return value using "eg.result".
Example:
class GetContentsOfVariable( eg.ActionClass ) :
    def __call__( self ) :
        return self.plugin.variable
Regards
Prinz
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
Post by krambriw » Sun Dec 13, 2009 10:01 pm
Dear Prinz,
Thank you very much!
Post by krambriw » Mon Dec 21, 2009 6:23 am
Hello again,
After experimenting a bit, the Getter action worked of course perfectly so thanks for the help?
However, I run into another interesting nut to crack;
I have below the very simplified code: A thread class, a plugin class and the action class for the "getter"
When the thread initialises, it gets the "variable" current value from the plugin as input. When it runs, its responsibility is to change the variable in the plugin if the value changes
The getter action reads the variable from the plugin on demand
The getter works as expected but the thread never succeeds in changing the value in the plugin...any suggestions?
In other words maybe I can say that I would like to change a variable value in a plugin class from a thread class
Simplified thread
class MyThread(Thread):
    def __init__(
        self,
        variable
        Thread.__init__(self, name="test")
        self.name = name
        self.aVariable= aVariable
    def run(self):
        while (self.abort == False):
        if self.aVariable != aVariablePrevious:
            self.plugin.variable = self.aVariable
The simplified plugin code
class MyPlugin(eg.PluginClass):
    def __init__(self):
        self.started = False
    def __start__(
        self,
        variable
        self.variable = variable
        self.started = True
The getter action
Post by krambriw » Mon Dec 21, 2009 10:45 am
Sorry, needed to bump this up
stottle
Post by stottle » Mon Dec 21, 2009 5:11 pm
Your simplified code looks incomplete.
I think you should define both aVariable and aVariablePrevious in the thread init, as the if statement should raise an exception since aVariablePrevious isn't defined. Also, I don't see where your thread gets a reference to plugin, so I think your code would raise an exception there if it didn't at aVariablePrevious.
Is there a more complete example?
Brett
Post by krambriw » Mon Dec 21, 2009 6:30 pm
Yes, it is too simplified. I will try to make a working skeleton
Thanks for your support,
Walter
Post by krambriw » Mon Dec 21, 2009 8:19 pm
I have created a simple skeleton plugin. It's a scheduler that runs threads that just increments a counter every fifth second and creaes an event.
What I want to do is in this part of the code
    def run(self):
            self.finished.wait(5)
            self.finished.clear()
            if self.abort:
                break
            eg.TriggerEvent(str(self.t_variable))
            self.t_variable += 1
            self.variable = self.t_variable
I would like to change the last line above to
self.plugin.variable = self.t_variable
but it fails
(8.45 KiB) Downloaded 257 times
Prinz
Post by Prinz » Mon Dec 21, 2009 9:07 pm
the class SchedulerThread is not based on the eg.ActionClass. In this case the variable self.plugin is unknown.
You can solve this problem, if the plugin is added up as a parameter to the __init__ of the SchedulerThread class.
Eample:
class SchedulerThread(Thread):
    def __init__(self,
        name,
        variable,
        plugin
    self.plugin = plugin
If the the class is instanciated in the plugin class, the following statement can be used:
        t = SchedulerThread(
            schedulerName,
            variable,
            self
Regards
Prinz
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
Post by krambriw » Mon Dec 21, 2009 9:30 pm
Oh great, thank you very much, I will try this approach
