USB-UIRT: proposal to introduce retries
Post by krambriw » Fri Dec 04, 2009 11:05 am
I have a problem when multiple threads are hitting the USB-UIRT at the same time. The following code (in the class TransmitIR) is a proposal to change the plug-in and to introduce handling of retries.
I have noticed that it seems to work (got already several entries in log due to retries) as I expected
    def __call__(self, code='', repeatCount=4, inactivityWaitTime=0):
        if not self.plugin.dll:
            print "dll"
            raise self.Exceptions.DeviceNotReady
        if len(code) > 5:
            start = 0
            if code[0] == "Z":
                start = 2
            if code[start+3] == "R":
                codeFormat = UUIRTDRV_IRFMT_UUIRT
            elif code[start+4] == " ":
                codeFormat = UUIRTDRV_IRFMT_PRONTO
                codeFormat = UUIRTDRV_IRFMT_LEARN_FORCESTRUC
            repeatCount = 0
            code = ""
### Modified by Walter Kraembring. Introduced retries
        bSuccess = False
        for i in range(0,3):
            if i>0:
               print "USB-UIRT retries: ", i
               time.sleep(0.5)
            if self.plugin.dll.UUIRTTransmitIR(
                self.plugin.hDrvHandle,    # hHandle
                c_char_p(code),     # IRCode
                codeFormat,         # codeFormat
                repeatCount,        # repeatCount
                inactivityWaitTime, # inactivityWaitTime
                0,                  # hEvent
                0,                  # reserved1
                0                   # reserved2
                bSuccess = True
                break
        if not bSuccess:
### End modification
Bartman
Re: USB-UIRT: proposal to introduce retries
Post by Bartman » Mon Dec 07, 2009 10:37 pm
How do you use the USB-UIRT from multiple threads?
Post by krambriw » Wed Dec 09, 2009 10:33 am
I use my Scheduler and SunTracker and there I have multiple threads running that creates events. Many times they are issuing events that activates the USB-UIRT for transmission. If those are with too little delay, they wont be accepted.
A little "for loop" with retries has showed that it now works on the first or second retry
Post by krambriw » Sat Dec 26, 2009 8:24 am
Here is a sample from my eg log that shows the difference, with and without the above code change
Without the code change (original)
23:27:01         USB-UIRT: Transmit IR
23:27:02            Device is not ready!
23:27:02   Main.SB_Bathroom_ON
23:27:03      B1_ON USB-UIRT: Transmit IR
23:27:03         USB-UIRT: Transmit IR
23:27:03   Main.Garage ON
23:27:03      B13_ON USB-UIRT: Transmit IR
With the code modification as proposed
00:57:04   Main.SB_Kitchen_ON
00:57:04      A3_ON USB-UIRT: Transmit IR
00:57:04         USB-UIRT: Transmit IR
00:57:04   Main.SB_Bathroom_ON
00:57:04      B1_ON USB-UIRT: Transmit IR
00:57:06   Main.SB_Kitchen_ON
00:57:06      A3_ON USB-UIRT: Transmit IR
00:57:06         USB-UIRT: Transmit IR
00:57:06            USB-UIRT retries:  1
00:57:07            USB-UIRT retries:  2
00:57:09   Main.SB_Bathroom_ON
00:57:09      B1_ON USB-UIRT: Transmit IR
00:57:09         USB-UIRT: Transmit IR
00:57:09            USB-UIRT retries:  1
00:57:10            USB-UIRT retries:  2
00:57:11   Main.SB_Kitchen_ON
00:57:11      A3_ON USB-UIRT: Transmit IR
00:57:11         USB-UIRT: Transmit IR
00:57:13   Main.SB_Bathroom_ON
00:57:13      B1_ON USB-UIRT: Transmit IR
00:57:13         USB-UIRT: Transmit IR
00:57:13            USB-UIRT retries:  1
00:57:14            USB-UIRT retries:  2
