EG can handle post messages without any problem. In fact, here's an example plugin to do what you want. The only thing you should need to add is the name of the executable so EG can find the window to post to. Add whatever else you want, change the author name, and you should be good to go.
Note, I don't have MulticastTV, so I can't test this out.
version="0.1"
# Plugins/MulticastTV/__init__.py
eg.RegisterPlugin(
name = "MulticastTV",
author = "Brett Stottlemyer",
version = version,
kind = "program",
description = (
'Adds actions to control MulticastTV - IPTV client app.'
createMacrosOnAdd = True,
from win32gui import PostMessage
windowMatch = u'NAME OF PROGRAM FROM TASK MANAGER' #<--Change This
myExe = windowMatch + u'.exe'
FindMulticast = eg.WindowMatcher(myExe, None, None, None, None, 1, False, 0.0, 0)
class wmAction(eg.ActionClass):
def __call__(self):
hwnds = FindMulticast()
if len(hwnds) != 0:
PostMessage(hwnds[0], 34952, self.value, 0)
self.PrintError("Multicast is not running.")
return
class Multicast(eg.PluginClass):
def __init__(self):
self.windowMatch = windowMatch
self.AddActionsFromList(ACTIONS)
ACTIONS = (
(wmAction,"Previous", "Previous", "Previous", 65536),
(wmAction,"1","1","1",1),
(wmAction,"2","2","2",2),
(wmAction,"3","3","3",3),
(wmAction,"4","4","4",4),
(wmAction,"5","5","5",5),
(wmAction,"6","6","6",6),
(wmAction,"7","7","7",7),
(wmAction,"8","8","8",8),
(wmAction,"9","9","9",9),
(wmAction,"0","0","0",0),
(wmAction,"Volume Down","Volume Down","Volume Down",11),
(wmAction,"Volume Up","Volume Up","Volume Up",12),
(wmAction,"Channel Up","Channel Up","Channel Up",13),
(wmAction,"Channel Down","Channel Down","Channel Down",14),
(wmAction,"Record","Record","Record",15),
(wmAction,"Back","Back","Back",16),
(wmAction,"OSD Channel","OSD Channel","OSD Channel",18),
(wmAction,"Full Screen","Full Screen","Full Screen",19),
(wmAction,"Table","Table","Table",20),
(wmAction,"Mute","Mute","Mute",21),
(wmAction,"Pause","Pause","Pause",22),
(wmAction,"Play Faster","Play Faster","Play Faster",23),
(wmAction,"Play Slower","Play Slower","Play Slower",24),
(wmAction,"Snapshot","Snapshot","Snapshot",25),
(wmAction,"Recall","Recall","Recall",26),
(wmAction,"Aspect Ratio","Aspect Ratio","Aspect Ratio",27),
(wmAction,"Crop","Crop","Crop",28),
(wmAction,"Left","Left","Left",102),
(wmAction,"Right","Right","Right",103),
(wmAction,"Up","Up","Up",100),
(wmAction,"Down","Down","Down",101),
(wmAction,"PIP","PIP","PIP",29),
(wmAction,"Epg scroll up","Epg scroll up","Epg scroll up",30),
(wmAction,"Epg scroll down","Epg scroll down","Epg scroll down",31),
(wmAction,"Epg zoom in","Epg zoom in","Epg zoom in",32),
(wmAction,"Epg zoom out","Epg zoom out","Epg zoom out",33),
(wmAction,"Epg Show","Epg Show","Epg Show",34),
(wmAction,"Teletext","Teletext","Teletext",35),
(wmAction,"Epg background toggle","Epg background toggle","Epg background toggle",36),
(wmAction,"Exit","Exit","Exit",99),
(wmAction,"Stop","Stop","Stop",37),
(wmAction,"Audio track","Audio track","Audio track",38),
