MD5 Hash Question
jsonnabend
MD5 Hash Question
Post by jsonnabend » Sun Feb 08, 2009 3:13 pm
I'm messing with some code to communicate with EventGhost over a network.
I'm sending 'quintessence' and getting back a four character cookie. I'm not sure I'm calculating the MD5 hash correctly. Can someone confirm that, with no password set, the has should be calculated on COOKIE+ ":" with nothing after the ":"? In other words, if the cookie is "1ab2" then the hash should be calculated on "1ab2:" .
Also, I should be sending MD5HASH + \n, correct?
TIA
- Jeff
jsonnabend
Re: MD5 Hash Question
Post by jsonnabend » Tue Feb 10, 2009 8:28 pm
BUMP
Nothing, huh? :(
jinxdone
Post by jinxdone » Wed Feb 11, 2009 1:46 pm
Hello.
I assume you have looked in the network sender and network receiver code? The code looks pretty simple to follow and with a quick look It seems to me like you are correct in your string forming and hashing..
So are you having a problem with it or..? There was some prior discussion about this plugin in this thread, maybe you are also having trouble with wrong newline/carriage return characters that end of the string you are sending?
-jinxdone
jsonnabend
Post by jsonnabend » Wed Feb 11, 2009 2:10 pm
I did recall that thread, and was able to catch the CR/LF issue. I am sending the quintessence part no problem and then receiving a four character "cookie" from EG. I then add the colon, run the hash and send it back to EG with a LF appended. I then get nothing but silence from EG.
- Jeff
jsonnabend
Post by jsonnabend » Wed Feb 11, 2009 2:19 pm
Ah! Found the error. I was stripping the LF off of the cookie, storing it in a new variable, and then using the old, non-stripped cookie to generate the hash! Duh. Thanks for the info. I will play some more this weekend.
- Jeff
Melloware
Post by Melloware » Thu Feb 19, 2009 6:27 pm
jsonnabend wrote:Ah! Found the error. I was stripping the LF off of the cookie, storing it in a new variable, and then using the old, non-stripped cookie to generate the hash! Duh. Thanks for the info. I will play some more this weekend.
- Jeff
Yep that bit me too when i was working on the EventPhone iPhone stuff. I modeled it after the Network Receiver code but could not quite figure it out when sending from the iPhone. Turned out to be CR LF issues also.
Melloware Inc.
EventPhone iPhone Application
