[Done] process monitoring plugin
I'm trying to create a process monitoring plugin. The challenge, I never coded in python but I already did this in C#.
I would like to do exactly like the task plugin but for the processes (windows CTRL-ALT-DEL process list). I would like to create two new event
- created.xxx (where xxx is the process name)
- closed.xxx (where xxx is the process name)
I founded this (in french) http://www.developpez.net/forums/d38466 ... sus-cours/
Is it possible to create this plugin without installing special libraries ? Could you help me to start ?
Re: Help trying to create a process monitoring plugin
I probably does not understand exactly what you need.DranDane wrote:Is it possible to create this plugin without installing special libraries ? Could you help me to start ?
Maybe this will help you: http://mail.python.org/pipermail/python ... 06174.html
I already use and it works.
I would like to raise an event on process creation/destruction. Exactly like the Task plugin does for the task but for the process.
I understand it before, but I am not entirely sure you what you mean by the following:DranDane wrote:I would like to raise an event on process creation/destruction. Exactly like the Task plugin does for the task but for the process.
PakoDranDane wrote:Is it possible to create this plugin without installing special libraries ?
- Bitmonster
There is a function called GetProcessDict() in eg.cFunctions coded in C (and therefore should be fast) that should help. It returns a dict where the keys are the PIDs and the values are the names of the processes. I just hacked this script together:
from eg.cFunctions import GetProcessDict
from threading import Thread
from time import sleep
from os.path import splitext
def ThreadFunc():
oldProcesses = GetProcessDict()
oldPids = set(oldProcesses.iterkeys())
while True:
newProcesses = GetProcessDict()
newPids = set(newProcesses.iterkeys())
for pid in newPids.difference(oldPids):
name = splitext(newProcesses[pid])[0]
eg.TriggerEvent("Created." + name, prefix="Process")
for pid in oldPids.difference(newPids):
name = splitext(oldProcesses[pid])[0]
eg.TriggerEvent("Destroyed." + name, prefix="Process")
oldProcesses = newProcesses
oldPids = newPids
sleep(0.1)
Thread(target=ThreadFunc).start()
Are you sure because if i add this line to my script :
The loading of the module fails. I get a "Process not found" error message.
Hi Bitmonster,
Is GetProcessDict in the latest (0.3.5c.908) release version ?
Are you building the cFunctions library with Visual Studio ?
Last beta version (0.3.6.1487) included GetProcessDict and it works very nicely.
Plugin is actually already finished.
Where can I dowload this beta version ? On the sourceforge page I can only download the 3.5c.
EDIT -- OK found (http://www.eventghost.org/downloads/) Thanks to google
And now I see the answer is on the main wiki page. I must learn to read.
The code for the process plugin is done. I did the easiest part. Thank you Bitmonster for the GetProcessDict function and the example. I know nothing about Python so I did a simple mix between the example of Bitmonster and the code from the DirectoryWatcher module :
Could you to add this to the SVN ?
eg.RegisterPlugin(
name = "Process Watcher",
author = "Bitmonster & DranDane",
version = "1.0.",
description = (
"Generates events if a process is created or destoyed"
icon = (
"iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAABuklEQVR42o1Sv0tCYRQ9"
"L1FccpCEB73wVy1NjTrUPxD1lgZp0dWKaAhXxWhoyWgoIUjHBEH65RSE0CAUgWIPLAqR"
"gkAQIQXR8nW/Z0ai6btweJfDd847934fhz8VCARkqCjTmBGra+sc67kOGQqFZIfDMVCo"
"1WphMpng9/vxkMvi9u6e4zp/ZmStVkOpVOor1mg00Ol0CIfDKBQK/Q1isRhcLhedJpIn"
"vHXkI+D5SUSj+0in0wMM4mSw6WqL9whLhHeCYAA/tobo9twQgxsyEMjglUj6IE7YIJxQ"
"gk9K8DwsgTLCMjGGdvJxJibMUgJ+hUaYGWyQSCQQDO7+ZO8uo1EHn8/2v4Hb7UYmkxl4"
"jY1GA9lsFrlcDl+fDZxfJNsGHo9H1QNiVa/XlQSiuIAp2wS466ukHNjaUauHXq+H0+n8"
"HYPrzF+pVHriSpLUxbGHJAgCIpFIr0EqlYI0KmH6Y1o5XC6XaaFBpW+1WqhWq7BYLLRI"
"X9ciFQNRFJHP53FoO4T3xdsTu9lsolgswm63Kz1b9tPTI6xmAVzk+Eg+PbtUvQNWstxS"
"xHv7B+1bEBfnVd8CK6vFrIhZ/w1wBAQrC42uqQAAAABJRU5ErkJggg=="
import threading
from eg.WinApi.Dynamic import (
# functions:
CreateEvent,
PulseEvent,
class Process(eg.PluginClass):
def __start__(self):
self.stopEvent = CreateEvent(None, 1, 0, None)
self.startException = None
startupEvent = threading.Event()
self.thread = threading.Thread(
target=self.ThreadLoop,
name="ProcessWatcherThread",
args=(startupEvent,)
self.thread.start()
startupEvent.wait(3)
if self.startException is not None:
raise self.Exception(self.startException)
def __stop__(self):
if self.thread is not None:
PulseEvent(self.stopEvent)
self.thread.join(5.0)
def ThreadLoop(self, stopThreadEvent):
while True:
oldPids = newPids
sleep(0.1)
- __init__.py
- Process module
- (2.58 KiB) Downloaded 743 times
Re: [Done] process monitoring plugin
I've added FindProcess and CloseProcess actions in the manner as the similar Window functions, and while it's mostly working, I'm having some problems. Every time I close and re-open EG to reload the module, the actions have detached, and I get a...
When I recreate the actions, it works fine, but obviously I'm doing something wrong.
Can't find action: Process.FindProcess(u'XWin.exe')
Can't find action: Process.CloseProcess()
so can this be used to kill a process?
