Just thought I'd share my CM11A plugin, in case others find it useful.
The CM11A X10 interface is natively supported via serial interface, no other software is needed. Most basic X10 commands are implemented. Events get generated for any command the CM11A receives from the powerline. Macro functionality is not implemented as I do not use it and do not think that it would add much to what Eventghost already offers.
Code attached.
CM11A (serial) plugin
- CM11A.zip
- Unpack the content in the plugins directory.
- (3.94 KiB) Downloaded 268 times
- Bitmonster
Re: CM11A (serial) plugin
Funny there is no comment till now. The plugin looks nicely written, but I have no X10 powerline device to test it. With some more confirmations, that this actually works, I would like to include it in the distribution.
It's been pretty solid for me, although clearly it would be nice to hear how/if it worked for others too.
Here's a new version, with fixes and some new features.
- CM11A.zip
- Version 0.2. Unpack in the plugins directory.
- (4.11 KiB) Downloaded 273 times
- Bitmonster
I have added you to the "Plugin Developer" group. So you can know open up a topic for this plugin in the Plugin forum. Maybe this gives a little more publicity.
