I'm trying to convert a girder plugin I wrote for using the usb ir receiver that comes with my asus p5w dh motherboard.
the girder plugin is as follows:
// AsusP5W_Girder.cpp : Defines the entry point for the DLL application.
#include "stdafx.h"
LRESULT CALLBACK WndProc(HWND hWnd, UINT message, WPARAM wParam, LPARAM lParam);
ATOM registerClass(HINSTANCE hInstance)
WNDCLASSEX wcex;
wcex.cbSize = sizeof(WNDCLASSEX);
wcex.style = CS_HREDRAW | CS_VREDRAW;
wcex.lpfnWndProc = WndProc;
wcex.cbClsExtra = 0;
wcex.cbWndExtra = 0;
wcex.hInstance = hInstance;
wcex.hIcon = NULL;
wcex.hCursor = LoadCursor(NULL, IDC_ARROW);
wcex.hbrBackground = (HBRUSH)(COLOR_WINDOW+1);
wcex.lpszMenuName = NULL;
wcex.lpszClassName = L"AsusP5W_Girder";
wcex.hIconSm = NULL;
return RegisterClassEx(&wcex);
BYTE button;
LRESULT CALLBACK WndProc(HWND hWnd, UINT message, WPARAM wParam, LPARAM lParam) {
switch (message) {
case WM_CREATE: {
RAWINPUTDEVICE Rid[1];
Rid[0].usUsagePage = 65280;
Rid[0].usUsage = 0;
Rid[0].dwFlags = RIDEV_PAGEONLY | RIDEV_INPUTSINK;
Rid[0].hwndTarget = hWnd;
RegisterRawInputDevices(Rid, 1, sizeof(RAWINPUTDEVICE));
break;
case WM_DESTROY:
PostQuitMessage(0);
break;
case WM_INPUT: {
UINT dwSize;
GetRawInputData((HRAWINPUT)lParam, RID_INPUT, NULL, &dwSize, sizeof(RAWINPUTHEADER));
LPBYTE lpb = new BYTE[dwSize];
GetRawInputData((HRAWINPUT)lParam, RID_INPUT, lpb, &dwSize, sizeof(RAWINPUTHEADER));
RAWINPUT* raw = (RAWINPUT*)lpb;
if (raw->header.dwType==RIM_TYPEKEYBOARD) {
dwSize = 0;
} else if (raw->header.dwType==RIM_TYPEHID) {
char txt[100];
if (raw->data.hid.bRawData[2]==0) {
KillTimer(hWnd,1);
} else {
sprintf(txt,"%i",raw->data.hid.bRawData[2]);
button = raw->data.hid.bRawData[2];
SendEventEx(txt, NULL, 0, 2000, EVENT_MOD_NONE);
SetTimer(hWnd,1,400,NULL);
delete[] lpb;
return 0;
case WM_TIMER:
char txt[100];
sprintf(txt,"%i",button);
SetTimer(hWnd,1,100,NULL);
break;
default:
return DefWindowProc(hWnd, message, wParam, lParam);
return 0;
#define PLUGINNUM 2000
#define PLUGINNAME "Asus P5W DH Deluxe Remote"
#define PLUGINDESC "Receive events from the USB receiver included with the Asus P5W DH Deluxe"
#define PLUGINVER "1.0"
#define APIVER 3
pCoreVars CoreVars = NULL;
HINSTANCE g_hInst;
HWND wnd;
int WINAPI gir_open(int gir_major_ver, int gir_minor_ver, int gir_micro_ver, pFunctions3 p) {
CoreVars = p->CoreVars;
// TODO: Extra start-up code goes here.
GirderLogMessageEx(PLUGINNAME, "Open", GLM_INFORMATION_ICON);
return GIR_TRUE;
int WINAPI gir_close() {
// TODO: Extra shut-down code goes here.
return GIR_TRUE;
int WINAPI gir_requested_api(int maxapi) {
return APIVER;
int WINAPI gir_devicenum() {
return PLUGINNUM;
void WINAPI gir_description(PCHAR Buffer, BYTE Length) {
strncpy(Buffer, PLUGINDESC, Length);
void WINAPI gir_name(PCHAR Buffer, BYTE Length) {
strncpy(Buffer, PLUGINNAME, Length);
void WINAPI gir_version(PCHAR Buffer, BYTE Length) {
strncpy(Buffer, PLUGINVER, Length);
BOOL APIENTRY DllMain(HINSTANCE hModule, DWORD dwReason, LPVOID lpReserved) {
g_hInst = hModule;
return TRUE;
int WINAPI gir_start() {
//TODO: Start the event generation mechanism,
registerClass(g_hInst);
wnd = CreateWindow(L"AsusP5W_Girder",L"AsusP5W_Girder",0,0,0,0,0,NULL,NULL,g_hInst,NULL);
return GIR_TRUE;
int WINAPI gir_stop() {
//TODO: Stop the event generation mechanism.
DestroyWindow(wnd);
return GIR_TRUE;
eg.RegisterPlugin(
name = "Asus P5W DH remote",
author = "",
version = "1.0." + "$LastChangedRevision: 314 $".split()[1],
kind = "remote",
description = (
'Plugin for USB IR Reciever of Asus P5W DH Motherboard'
import os
from threading import Timer
from msvcrt import get_osfhandle
import _winreg
import ctypes
from ctypes import Structure, Union, c_byte, c_char, c_int, c_long, c_ulong, c_ushort, c_wchar
from ctypes import pointer, byref, sizeof, POINTER, cast
from ctypes.wintypes import ULONG, BOOLEAN, BYTE
from eg.WinApi.Dynamic import (
WinDLL,
windll,
WINFUNCTYPE,
POINTER,
HWND ,
HMODULE ,
c_uint,
c_void_p,
c_char_p,
WNDCLASS,
GetDesktopWindow,
WNDPROC,
CreateWindow,
WinError,
RegisterClass,
WS_OVERLAPPEDWINDOW,
CW_USEDEFAULT,
WM_TIMER,
pointer,
DestroyWindow,
UnregisterClass,
GetTickCount,
DWORD,
HANDLE,
WPARAM
class RAWINPUTDEVICE(Structure):
_fields_ = [
("usUsagePage", c_ushort),
("usUsage", c_ushort),
("dwFlags", DWORD),
("hwndTarget", HWND),
class RAWHID(Structure):
_fields_ = [
("dwSizeHid", DWORD),
("dwCount", DWORD),
("bRawData", BYTE),
class RAWINPUTHEADER(Structure):
_fields_ = [
("dwType", DWORD),
("dwSize", DWORD),
("hDevice", HANDLE),
("wParam", WPARAM),
class RAWINPUT(Structure):
class RAWINPUT_DATA_VALUE(Union):
_fields_ = [
("mouse", DWORD),
("keyboard", DWORD),
("hid",RAWHID),
_fields_ = [
("header", RAWINPUTHEADER),
("data", RAWINPUT_DATA_VALUE),
WM_INPUT = 0x00FF
RIDEV_PAGEONLY = 0x00000020
RIDEV_INPUTSINK = 0x00000100
RID_INPUT = 0x10000003
RIM_TYPEMOUSE = 0
RIM_TYPEKEYBOARD = 1
RIM_TYPEHID = 2
class AsusMessageReceiver(eg.ThreadWorker):
A thread with a hidden window to receive win32 messages from the driver
hwnd = None
dll = None
button = None
@eg.LogIt
def Setup(self, plugin):
This will be called inside the thread at the beginning.
self.plugin = plugin
wc = WNDCLASS()
wc.hInstance = GetDesktopWindow()
wc.lpszClassName = "AsusPluginEventSinkWndClass"
wc.lpfnWndProc = WNDPROC(self.MyWndProc)
if not RegisterClass(byref(wc)):
raise WinError()
self.hwnd = CreateWindow(wc.lpszClassName, "AsusPlugin Event Window", WS_OVERLAPPEDWINDOW, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, 0, 0, wc.hInstance, None)
if not self.hwnd:
raise WinError()
self.wc = wc
self.hinst = wc.hInstance
rid = RAWINPUTDEVICE()
rid.usUsagePage = 65280
rid.usUsage = 0
rid.dwFlags = RIDEV_PAGEONLY | RIDEV_INPUTSINK
rid.hwndTarget = self.hwnd
windll.user32.RegisterRawInputDevices(byref(rid), 1, sizeof(rid))
@eg.LogIt
def Finish(self):
This will be called inside the thread when it finishes. It will even
be called if the thread exits through an exception.
if self.hwnd:
windll.user32.KillTimer(self.hwnd, 1)
if self.hwnd:
DestroyWindow(self.hwnd)
UnregisterClass(self.wc.lpszClassName, self.hinst)
#@eg.LogIt
def MyWndProc(self, hwnd, msg, wParam, lParam):
if msg == WM_INPUT:
dwSize = c_uint(0)
windll.user32.GetRawInputData(lParam, RID_INPUT, 0, byref(dwSize), sizeof(RAWINPUTHEADER))
bytebuf = c_byte * dwSize.value
lpb = bytebuf()
windll.user32.GetRawInputData(lParam, RID_INPUT, byref(lpb), byref(dwSize), sizeof(RAWINPUTHEADER))
raw = cast(lpb, POINTER(RAWINPUT))
if raw.header.dwType == RIM_TYPEHID:
charbuf = c_char * 100;
if (raw.data.hid.bRawData[2]==0):
button = raw.data.hid.bRawData[2]
self.TriggerEvent(button)
windll.user32.SetTimer(self.hwnd, 1, 400, NULL)
if msg == WM_TIMER:
windll.user32.SetTimer(self.hwnd, 1, 100, NULL)
return 1
def OnTimeOut(self):
self.keyStillPressed = False
self.lastEvent.SetShouldEnd()
class AsusIR(eg.PluginClass):
class text:
buttonTimeout = "Button release timeout (seconds):"
buttonTimeoutDescr = (
"(If you get unintended double presses of the buttons, "
"increase this value.)"
def __start__(self, waitTime=0.15):
self.msgThread = AsusMessageReceiver(self)
self.msgThread.Start()
@eg.LogIt
def OnComputerSuspend(self, suspendType):
self.__stop__()
@eg.LogIt
def OnComputerResume(self, suspendType):
self.__start__()
def __stop__(self):
self.msgThread.Stop()
I get a error on line 151 saying: AttributeError: 'LP_RAWINPUT' object has no attribute 'header'.
I'm sure it's not the only error, but any pointers would be appreciated.
