Importing python libraries to run script but which libraries?
Re: Importing python libraries to run script but which libraries?
Post by kgschlosser » Wed May 16, 2018 7:59 pm
I need to see the printouts. The lines that get printed when it states it located the server
something like the following
Found Emby Server
Name: Some Server Name
Address: http:\\SomeServerAddress
It is having a problem parsing the url that is returned by the Emby server. so unless I know what that line reads i do not know how i need to modify it so it will work.
the error is telling me that it is failing to parse "192.168.29.195:8096\Sessions" which would be missing the http:\\ but i accounted for that in the last update and we still have the same error. So i need to know what the exact address is that is given by the Emby server and the printout mentioned above is going to give me exactly that. Once i have that I will be able to modify the URL so it will work.
jachin99
Post by jachin99 » Thu May 17, 2018 1:13 am
I ran this script (Copied directly from EG minus my API Key)
# only the API key is needed
emby_api_key = 'Key'
import requests
import os
import traceback
import socket
import json
from uuid import uuid4 as GUID
from pytube import YouTube
client_id = str(GUID())
sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM, socket.IPPROTO_UDP)
sock.setsockopt(socket.SOL_SOCKET, socket.SO_BROADCAST, True)
sock.settimeout(2.0)
broadcast_address = ('255.255.255.255', 7359)
sock.sendto('who is EmbyServer?', broadcast_address)
try:
    data = sock.recv(4096)
except socket.timeout:
    eg.PrintError('Could not find an Emby Server')
    eg.StopMacro()
    eg.Exit()
data = json.loads(data.decode('utf-8'))
eg.Print('Found Emby Server')
eg.Print('Name: ' + data['Name'])
eg.Print('Address: ' + data['Address'])
eg.Print('Id: ' + data['Id'])
headers = {
    'Content-Type': "application/json",
    'Accept':       "application/json",
    'x-emby-authorization': 'MediaBrowser',
    'Client':               'EmbyTrailers',
    'Device':               'Python Script',
    'DeviceId':             client_id,
    'Version':              '1.0.0.0',
emby_url = data['Address']
session_url = '{0}\Sessions'.format(emby_url)
params = dict(api_key=emby_api_key)
try:
    response = requests.get(session_url, headers=headers, params=params)
except requests.HTTPError:
    traceback.print_exc()
    eg.StopMacro()
    eg.Exit()
params.update(dict(DeviceId=client_id, Format='json'))
users_url = '{emby_url}/Users'.format(emby_url=emby_url)
items_url = '{emby_url}/Items'.format(emby_url=emby_url)
log_output = 'Emby Trailer Download Stats\n'
try:
    response = requests.get(users_url, headers=headers, params=params)
    users = response.json()
    eg.StopMacro()
    eg.Exit()
except ValueError:
    print response.status_code
    print response
    eg.StopMacro()
    eg.Exit()
    params.update(
        dict(
            IncludeItemTypes='Movie',
            Recursive=True,
            StartIndex=0,
            Fields='RemoteTrailers, Path'
    for user in users:
        params['UserId'] = user['Id']
        try:
                items_url,
                headers=headers,
                params=params
            films = response.json()
            eg.StopMacro()
            eg.Exit()
        except ValueError:
            print response
            eg.StopMacro()
            eg.Exit()
            questionable_trailers = 0
            missing_trailers = 0
            successful_trailer_downloads = 0
            failed_trailer_downloads = 0
            for film in films['Items']:
                if not film['LocationType'] == 'FileSystem':
                    continue
                if film['LocalTrailerCount'] == 0:
                    questionable_trailers += 1
                    film_path = film['Path'].encode('utf-8')
                    film_file_name = os.path.basename(film_path)
                    film_directory_name = os.path.dirname(film_path)
                    film_name = os.path.splitext(film_file_name)[0]
                    if film_name[-3:-1] == 'CD':
                        film_name = film_name[:-4]
                    def download_trailer(trailer_file_name):
                        global missing_trailers
                        global successful_trailer_downloads
                        global failed_trailer_downloads
                        missing_trailers += 1
                        for trailer in film['RemoteTrailers']:
                            trailer_url = trailer['Url'].encode('utf-8')
                            try:
                                you_tube = YouTube(trailer_url)
                                you_tube.set_filename(trailer_file_name)
                                video = you_tube.filter('mp4')[-1]
                                video.download(film_directory_name)
                                successful_trailer_downloads += 1
                                break
                            except:
                                eg.PrintError(
                                    '{0} - {1}'.format(film_name, trailer_url)
                            failed_trailer_downloads += 1
                    film_directory_contents = os.listdir(film_directory_name)
                    if (
                        'VIDEO_TS' in film_directory_contents or
                        'BDMV' in film_directory_contents
                        film_directory_name = os.path.join(
                            film_directory_name,
                            'trailers'
                        if not os.path.exists(film_directory_name):
                            os.mkdir(film_directory_name)
                        for f in os.listdir(film_directory_name):
                            if f.startswith('trailer'):
                                break
                            download_trailer('trailer')
                            if f.startswith(film_name + '-trailer'):
                                break
                            download_trailer(film_name + '-trailer')
            film_output_template = (
                'User: {0}\n'
                '    Reported Download Count: {1}\n'
                '    Actual Download Count: {2}\n'
                '    Successful Downloads: {3}\n'
                '    Failed Downloads: {4}\n\n'
            log_output += film_output_template.format(
                user.Name,
                questionable_trailers,
                missing_trailers,
                successful_trailer_downloads,
eg.Print(log_output)
And got this screen
jachin99
Post by jachin99 » Thu May 17, 2018 1:18 am
Others have chimed in on a thread I have for this on the Emby forums. One suggestion was to look at the EmbyCon code (Written in python) for examples. I'm posting this here in case it helps. https://github.com/faush01/plugin.video ... adutils.py
Post by kgschlosser » Thu May 17, 2018 2:27 am
my dumbass had the wrong slash... needed to be a / instead of a \
I change the script there is no need iterate through the users and then iterate the films for that user. it is kind of a dumbass thing to do because a movie is a movie. and it has absoutly nothing to do with the user. The only thing using the user does is return things like favorite or suggestions and it has nothing to do with the library it's self.
So I have this thing simply going through every movie in the library. no reason to make it work more then it needs to.
import requests
import os
import traceback
import socket
import json
try:
    eg.StopMacro()
    eg.Exit()
headers = {
session_url = '{0}/Sessions'.format(emby_url)
try:
    session = requests.get(session_url, headers=headers, params=params).json()
    eg.StopMacro()
    eg.Exit()
params.update(
    dict(
        DeviceId=client_id,
        Recursive=True,
        StartIndex=0,
        Fields='RemoteTrailers, Path',
        Format = 'json'
try:
    response = requests.get(items_url, headers=headers, params=params)
    films = response.json()['Items']
    eg.StopMacro()
    eg.Exit()
except ValueError:
    print response
    eg.StopMacro()
    eg.Exit()
    for film in films:
            continue
                    try:
                        break
                    except:
                        eg.PrintError(
            if (
                    'trailers'
                        break
                        break
    eg.Print(
            missing_trailers,
jachin99
Post by jachin99 » Thu May 17, 2018 4:08 pm
No worries, your making good progress, and I think we are past the authentication part of this because it starts iterating through the folders but I still get an error. I think this script was built on an old version of pytube, and there is a change to the version I'm running which I will get into soon but first some screenshots
I googled around a bit, and found a few others have had problems.
https://github.com/nficano/pytube/issues/164
I'm thinking the version of pytube I'm on is 9.2.2-18 because this number is reflected in the name of the file I downloaded when I added the libraries. I hope that at least gives you an idea about what could be going wrong, and thanks again
Post by kgschlosser » Thu May 17, 2018 5:41 pm
new option. you get to pick the resolution you want for the trailer.
trailer_resolution = '1080p'
# other choices 360p 720p 480p 240p, 144p
import requests
import os
import traceback
import socket
import json
try:
    eg.StopMacro()
    eg.Exit()
headers = {
try:
    eg.StopMacro()
    eg.Exit()
params.update(
    dict(
        DeviceId=client_id,
        Recursive=True,
        StartIndex=0,
        Format='json'
try:
    eg.StopMacro()
    eg.Exit()
except ValueError:
    print response
    eg.StopMacro()
    eg.Exit()
    for film in films:
            continue
                    try:
                        streams = you_tube.streams.filter(
                            file_extension='mp4',
                            resolution=trailer_resolution,
                            progressive=True
                        ).all()
                        if streams:
                            stream = streams[0]
                            stream.download(
                                output_path=film_directory_name,
                                filename=trailer_file_name
                            break
                    except:
                        eg.PrintError(
            if (
                    'trailers'
                        break
                        break
    eg.Print(
            missing_trailers,
jachin99
Post by jachin99 » Thu May 17, 2018 9:09 pm
It looks like it worked. I have to check and see how well it performed but I see new files.
jachin99
Post by jachin99 » Thu May 17, 2018 9:22 pm
But I don't think they have audio unless the codec is incompatible with wmc. Just video
jachin99
Post by jachin99 » Fri May 18, 2018 2:55 am
This is really wierd. The trailers look fantastic and from what I can tell it got most of my movies but none of them have audio no matter what video player I open them with. I didn't see this coming at all.
Post by kgschlosser » Fri May 18, 2018 5:24 pm
lol. ok. i am hoping you didn't run this on you're production library. because it is going to be a real pain to delete the trailers. especially if you have a large library
Post by kgschlosser » Fri May 18, 2018 5:26 pm
also have you tried using shark007 codecs?
I would recommend installing it.
Post by kgschlosser » Fri May 18, 2018 5:41 pm
I also changed the script. apparently there are adaptive and progressive video files. these terms I have never head use to describe the handling of the audio. it's kinda dumb actually to use the term progressive to describe having the audio and video in the same transport stream file. the proper terms are actually mux and demux. mux or multiplexed is a single transport stream file. where as demuxed is a separate audio and video file. Now in the land of who ever made this library they thought the best way would be to default to a demuxed file and to name the argument that will provide a single transport stream "progressive", i really wish i could convey emotion through this thing better then these emoticons the board has. but these 2 are as close as it is going to get :roll: :oops: this one is i think supposed to be blushing bit it looks more like a pissed off angry face to me.
Post by kgschlosser » Fri May 18, 2018 5:43 pm
Now i would be curious to know since it defaulted to a demuxed transport stream. did it create 2 files when it downloaded the trailer or did it only download the video. which would be really nutty if it defaults to 2 files but then only saves one of them.
jachin99
Post by jachin99 » Fri May 18, 2018 7:40 pm
I have sharks installed, and I ran it on my production library. I didn't intend to starting out BUT lucky for me none of my actual movie files are .mp4 although I do have some video backgrounds that are. I just did a search of -trailer.mp4 in file explorer, and cleared them all out. I had 83 files with that name but I think I have around 120 video files in my movies library. I'll run your new script soon. I only saw one additional video or audio file for each movie after I ran the script. Thanks for all of the help again.
Post by kgschlosser » Fri May 18, 2018 9:00 pm
so that's a real hoot. it defaults to demuxing the stream but only saves the video side of it. to funny.
if you run this script. it will remove the trailers
import requests
import os
import traceback
import socket
import json
try:
    eg.StopMacro()
    eg.Exit()
headers = {
try:
    eg.StopMacro()
    eg.Exit()
params.update(
    dict(
        DeviceId=client_id,
        Recursive=True,
        StartIndex=0,
        Format='json'
try:
    eg.StopMacro()
    eg.Exit()
except ValueError:
    print response
    eg.StopMacro()
    eg.Exit()
    for film in films:
            continue
        if film['LocalTrailerCount']:
            if (
                    'trailers'
                    continue
            for f in film_directory_contents :
                if f.startswith('trailer')and f.endswith('mp4'):
                    os.remove(os.path.join(film_directory_name, f))
